Molopo n'a pas encore foré son premier puits pour extraire du gaz de schiste du sous-sol de Lévis, à Pintendre, qu'elle ne se gêne pas pour annoncer ses plans.
Voici le texte intégral qu'elle publie, à propos de ses activités, au Québec:
QUEBEC SHALE GAS
(100%)
Molopo controls 2.2 million acres of shale gas exploration acreage (also with conventional hydrocarbon potential) in Quebec, Canada. Of this, about 1.8 million acres was purchased from Amque LLC in January 2008 and 0.4 million acres was added later in 2008 and 2009 on application to the Quebec ministry of Natural Resources.
The purchase came with a very large database of well, seismic and aeromagnetic data. On the basis of this information, three new 2D seismic surveys of approximately 100km each were undertaken at Richelieu, Lyster and Pintendre. Following acquisition, it became clear that the new seismic data resolution is much improved over the old and as a consequence two exciting new play types emerged. Well locations have been selected in each of the three areas and are ready to drill.
The first planned well, St. marc sur Richelieu-1, is located 20km northeast of montreal and will target both the Utica Shale and channel sandstones. A drilling application was submitted to the Quebec Agricultural Commission (CPTAQ) on 20 November 2009 and as of 15 August 2010 the application had still not been approved. The Company is taking the opportunity to address the concerns expressed by local residents regarding the subsurface reservoir fracturing process.
Interpretation of new seismic data at the Lyster and Pintendre areas during the year generated attractive gas targets. At Lyster, a second new play type was identified, namely tight gas in the Potsdam formation siltstones. With modern stimulation techniques, molopo believes this formation has the potential to produce gas at commercial rates and is analogous to some tight gas plays currently producing in the USA. The structure mapped at Lyster is very large at 118 sq km and is estimated to contain gas- in-place of over 4TCF. Approximately 30% of this structure lies within molopo's permits.
At Pintendre, a deep Utica shale prospect of 12,000 acres is mapped with estimated gas-in-place of 2.7TCF.
molopo will consider opportunities for partners to participate in drilling both Lyster and Pintendre.
Very encouraging Utica Shale test results continued to be recorded by other operators in the play. A Talisman/ Questerre well reported a stabilised rate of 5 million standard cubic feet per day (mmscf/d) from a 1,000m lateral with an 8 stage fractrure stimulation. In addition, Gastem Inc. announced results from two vertical wells in an exploration licence contiguous with molopo's Richelieu East licence where an initial flow rate of 1.8mmscf/d and a stabilised flow rate of 0.2mmscf/d were reported.
The focus of the Company's programme over the next 12 months will be the drilling, completion and testing of St. marc sur Richelieu-1, drilling and testing follow-up wells as required and the acquisition of 70km of 2D seismic in the Bedford area. Relinquishment of some non-prospective acreage is also anticipated.
C'est quand même dingue qu'une transnationale ÉTRANGÈRE se soit si rapidement emparée d'un si gigantesque territoire HABITÉ du Québec pour y faire sa prospection et ensuite, son "exploitation" de NOS ressources naturelles.
Non-seulement des étrangers vont-ils avoir tout le loisir de nous prendre NOS ressources mais en plus, s'ils nous polluent et nous empoisonnent, ça ne les touchera même pas parce qu'ils sont basés... en Australie!
Et oui, nous avons accepté la "mondialisation" et là, nous allons nous faire entuber à coups de centaines de milliards de dollars qui vont nous glisser entre les doigts, au profit unilatéral de transnationales ÉTRANGÈRES.
Ça sert à quoi d'avoir un "ministère de l'Environnement" si les fon-fons qui y "dorment sur la switch" sont trop caves pour DIRE AUX QUÉBÉCOIS que nous avons, dans notre sous-sol, des centaines de fois ce qu'il nous faut pour devenir auto-suffisants, au plan énergétique... pour toujours?
Et bien, il semble que les fonctionnaires, ministres et autres poteaux de clôture n'auront pas à répondre de leur incompétence crasse à qui que ce soit. Ils vont continuer à collecter leurs gros chèques pendant qu'ils vendent leurs enfants à vil prix aux transnationales étrangères qui vont se faire un plaisir de nous vider les poches pendant qu'on regardait le train passer.
C'est ENRAGEANT de voir à quel point nous sommes incapables de prendre NOTRE DESTIN en main.
Ben non, il faut laisser les Molopo de ce monde, des étrangers basés à l'autre bout de la Terre, en Australie, venir prendre NOS RESSOURCES naturelles... presque gratuitement, en plus!
Ce que Molopo dit à ses actionnaires
- La carte géographique du territoire sous le contrôle de Molopo
- molopo_quebec_project_area.jpg (41.52 Kio) Vu 8042 fois
